Hello everybody, after extensive searching I was not able to get very good information regarding what wheels fit the S2000. So here are my questions, for those of you who are running the StopTech BBK on your S2000:
1. What Brand, Model, Diameter, Width, and offset are the wheels you're running?
2. Are you using a spacer? If so, what size is the spacer?
3. Were there any other mods required to fit the BBK?
I would like to put a list together and post it up here so that the question of what wheels will fit the StopTech BBK can finally be answered. I will also update the list as I receive more information from you guys.
Yeah let me know if you need help. I have had the same size brakes and larger brakes and can tell you first hand what will and what wont work with those calipers. Some shops still are giving out the wrong information.
Originally Posted by Project SSAP1,Aug 25 2005, 10:37 AM
I would like to know if the Brembo & Stoptech kits fit Prodrive GC-07 wheels...Wheels are 17x7.5 +48
Brembos should clear with no spacer. Stoptechs may require at the most a 3-5 mm spacer. The Endless calipers required a 3mm spacer with these exact wheel but to be really safe we went with a 5mm spacer.
nice...are the brembo's that much smaller than the stoptechs???? i printed out that diagram from stoptech site and im about to go do a test fit to see if they fit with no spacer..i will let u guys know what happens later today
