S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   low offset volk te-37 possible on s2k? (https://www.s2ki.com/forums/wheels-tires-56/low-offset-volk-te-37-possible-s2k-402091/)
happypuppy Jul 5, 2006 12:15 AM
just received a set of 18" te-37s with these specs on the sticker:
SIZE 18 x 7.5 J
PCD 100 OF. +30 5H CR
i searched the forums and found that high offsets are required for the s2k, but was wondering if it is possible to mount my te-37s onto my s2k? If so, what exactly will the low offset do to the car's appearance/handling? Any help will do. thanks guys.
Project22a Jul 5, 2006 01:00 AM
it's not even the right bolt pattern; so no, it won't fit. (and even if it was the correct pattern, that's too low of an offset)
xviper Jul 5, 2006 07:08 AM
Read this and you'll see why those aren't even close:
https://www.s2ki.com/forums/index.ph...&f=56&t=342793
Then you may not be a "happypuppy" anymore. :p
Jim@tirerack Jul 5, 2006 08:37 AM
If the wheel actually had the correct bolt pattern the offset would make the tires rub on the fenders. Also running the smae wheels and tires on all four corners is not a good idea on this car.
Send the wheels back and get a wheel to fit the car.
If I can help let me know.
happypuppy Jul 5, 2006 03:08 PM
thanks for the replies. I read through the fitment guide with the different offsets for the front and rear, but I'm still not too sure exactly what I should be getting. i'm looking into the te37s or ce28n, what ideal offset would anyone recommend for these wheels? i was thinking 17x7.5 front, 17x8.5 rear? Any recommendations or help for the offsets will do. thanks
04RioS2k Jul 5, 2006 05:51 PM
Steve at evolution can get you perfect volk fitment such as 17x7.5 49+ and 17x9 63 rear....you can check his thread here.....
https://www.s2ki.com/forums/index.php?showtopic=358329
© 2026 MH Sub I, LLC dba Internet Brands
