Ls 5 enkei
Enkei LS-5: 18x9
:: 5x114.3 :: 40mm offset :: Gloss Black -----------rear
Enkei LS-5: 18x8
:: 5x114.3 :: 40mm offset :: Gloss Black ------------front
should i get these ? are the offsets right?
will i rub?
Enkei LS-5: 18x8
will i rub?
Thanks
Remember, it is not the width that creates the rubbing as much as the offset. An 18x9+60 wheel will fit up front without rubbing, but the 18x8 +40 will. However, these could be fit with fender modification. See if you can find someone in your area to roll your fenders. Just remember
1) Tires will cost more in 18" sizes
2) These wheels are probably fairly heavy, so if performance is a goal then I would not get these.
What is your budget?
