S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Ls 5 enkei (https://www.s2ki.com/forums/wheels-tires-56/ls-5-enkei-739088/)
s2kZac Oct 19, 2009 04:14 AM
Ls 5 enkei
Enkei LS-5: 18x9
:: 5x114.3 :: 40mm offset :: Gloss Black -----------rear
Enkei LS-5: 18x8
:: 5x114.3 :: 40mm offset :: Gloss Black ------------front
should i get these ? are the offsets right?
will i rub?
Almostlude Oct 19, 2009 05:30 AM
Quick answer....
Yes you will rub, without some super neg camber, and bumper mod.
Jim@tirerack Oct 20, 2009 05:00 AM
That is right. Without modification and narrow tires this will not fit.
Valkdriver Jun 29, 2011 10:49 AM
How bad will it be? I really like the way these wheels look. I read the fitment guide and I see they are right on the border line by the numbers...actually a little bit past (18x8 front and 18x9 rear). Is there any feasible way to make it work? Any suggestions for a similar wheel?
Thanks
clarkster009 Jun 29, 2011 01:21 PM
Remember, it is not the width that creates the rubbing as much as the offset. An 18x9+60 wheel will fit up front without rubbing, but the 18x8 +40 will. However, these could be fit with fender modification. See if you can find someone in your area to roll your fenders. Just remember
1) Tires will cost more in 18" sizes
2) These wheels are probably fairly heavy, so if performance is a goal then I would not get these.
What is your budget?
© 2026 MH Sub I, LLC dba Internet Brands
