Lug Nuts for BBS RX
I am finding conflicting info on which lug nuts to use for a set of BBS RX in 17x8 all around. Spoke to tirerack hoping to order some but the salesperson was not at all helpful :( so still a little stuck.
Understand they are conical, but not sure about length and how thin they have to be to fit in the hole. i.e. would regular aftermarket nuts from auto zone work, or am I going to need BBS Specific... Thanks~! |
Looking at pics of those wheels you should be fine with pretty much any aftermarket conical lug. The length of the lug only matters if you have extended studs which I am guessing you don't. As for the width of the lug you shouldn't have to worry about that with these. Any muteki or gorilla lugs should work fine as long as they are conical.
| All times are GMT -8. The time now is 11:51 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
