S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Need Advice (https://www.s2ki.com/forums/wheels-tires-56/need-advice-607264/)
jmorale1 Jun 22, 2008 12:50 PM
Need Advice
So when I bought my car the owner put on some new tires but im positive they are not the right size. 245/45/17 rear 245/40/17 front....my question is how is this affecting my car (spedometer, performance, oversteer/understeer etc etc..) Also, if performance is my main concern what size should i get? i have an 05 on stock wheels and stock suspension.
silentdancer Jun 22, 2008 01:35 PM
215/45, 245/40 is stock sizing to get an idea.
jmorale1 Jun 22, 2008 01:48 PM
noob here so :ponder: explain please
1nate7 Jun 22, 2008 01:55 PM
A couple of issues here. You have a 245/40 on the front 7" wheel. Most tire manufacturers recommend running at least a 8" wide wheel with a 245 tire.
You have a 245/45 in the rear. This diameter is oversized by 1" compared to the stock 245/40. Your speedometer will be off, reading slower than your actual speed.
You are running 245 width tires all around. This will really increase oversteer. A lot of track guys do this, but usually counter it with a stiffer front sway bar and suspension tuning.
I would get a matching pair of 215/45 for the front and move the 245/40 to the rear. You will need to have the 245/40 dismounted and moved to the 8.5" rear wheels because I am assuming they put them on the 7" front wheels.
You can also upsize to 225/45, 255/40 but I would wait since you already have a perfectly good pair of 245/40 for the rear.
jmorale1 Jun 22, 2008 02:03 PM
if i didnt change anything and just waited till they wore...would the stock size be the best for handling with the stock suspension when i do get new tires? also what i have right now wont hurt the car right?
Penforhire Jun 22, 2008 03:54 PM
The OEM tires provide a very good driving experience. If I were you I'd start there and try different tires sometime later, after you have a basis to compare.
© 2026 MH Sub I, LLC dba Internet Brands
