Need help ordering spacers/studs
Old Jan 9, 2011 | 11:06 AM
tua40278's Avatar
Default Need help ordering spacers/studs
I need help installing a set of spoon calipers.
I need a 10 mm spacer with my RG2 wheels. That's pretty much all I know at this point.
Here's my questions. I realize not one person can answer all of these, but i appreciate all answers and opinions.
Are all H&R spacers hubcentric? I'd like to go with h&r because I've heard good things about them. I don't think I want to go with a spacer that isn't hubcentric like a kics and have to buy the hubcentric ring.
I realize if I buy the 10 mm h&r spacers, I'll need extended studs. What ones should I buy? Also, do extended studs only come in 2.85 inch's versus the stocks 1.5 inch length studs?
Right now I'm under the impression I'm going to buy H&R 10 mm spacers, arp extended studs, and hawk pads and be okay. Am I missing anything? To be honest, I feel like it's simple, but when I start looking online to purchase, all these brands and notes with products and everything is throwing me for a loop. It's suspension so I want to make sure I'm doing everything correctly. Thanks for the help guys.
Eric
Old Jan 9, 2011 | 01:04 PM
1nate7's Avatar
H & R 10mm spacers come with extended studs. I don't know the specs but I would be confident that they are good quality. You need 70.1 mm to match the front hub. The spacer will be hubcentric to the hub but not your wheel if that makes sense. Your wheel is likely the standard 73.1mm of most aftermarket wheels and not a perfect match to the stock hub or spacer. If you are worried about a hubcentric ring, it's something you should get even with the stock hub.
Link is for info only, you can shop around if you wish:
http://www.vividracing.com/catalog/trak-se...0-p-106450.html
I don't know if you are looking at HPS pads, but I would stick with stock over those.
fastkx125
May 12, 2011 03:29 PM
rob2.2
Dec 26, 2010 06:47 AM
tua40278
Apr 25, 2010 02:34 PM
The Gent
Dec 20, 2009 12:05 PM
cgutter
Sep 18, 2009 08:10 AM
