need help plz
Old Dec 29, 2003 | 12:55 AM
s2kvancouver's Avatar
Default need help plz
what is the largest tire u can fit on18x7.5 rim?
is 245 possible?
Old Dec 29, 2003 | 12:58 AM
SECRET AP1's Avatar
245 is as far as you'd want to go. I'm sure a tire shop wouldn't recommending going any wider.
wantone's Avatar
Assuming for the front, I would have to say 225.
Old Dec 29, 2003 | 01:11 AM
so u mean 245 will fit in 18X7.5 rim?
Old Dec 29, 2003 | 05:18 AM
blureds2k's Avatar
Moved to Tire and Wheel Forum.
Old Dec 29, 2003 | 06:18 AM
Stratocaster's Avatar
I am running 245/40/17, but see the thread stuck to the top of the Tire and wheel forum for more on this topic. This advice also applies to NON-OEM tires on any wheels too.
This advice applies to the Stock Rims, with NON-OEM tires
If you are not running the OEM tires on the rear of the S2K, you should be running a 245/45/16 in the rear.
Our stock 225 is NOT a real 225 and has a 8.5" contact patch which is the same as just about all other 245's out there.
205/55/16 in the front.
ToeKneeC
Apr 25, 2007 08:36 AM
t.vo408
May 10, 2006 04:57 PM
pushin9
Jul 13, 2005 06:02 AM
amongmany
Jan 8, 2004 05:14 PM
TypeSH
Apr 26, 2002 12:49 PM
