need help on these rims.. thinking of getting them
i got a good deal on some rims just wondering if i should get them?
they are..
18X8 +51 fronts and 18X9.5 +52 rear
will these fit my s2000? any rubbing? whats the tire size for these rims or biggest i can go? i will be lowering the car with eibach springs soon. oh and i have an AP2
thai,
they are..
thai,
They will fit at stock height but you should run 215/245 tire combo. a 225 in the front will likely rub with a drop. Not sure about the rears, you can most likely fit with adjustments to camber, I doubt you'll have to roll fenders unless you want to run wider tires.
good luck,
M
good luck,
M
