S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Need help with wheel/tire (https://www.s2ki.com/forums/wheels-tires-56/need-help-wheel-tire-774288/)
elcoqui1 Mar 17, 2010 04:24 PM
Ok, so I realize that my previous offsets were all wrong, so here is what I got:
wheel: front 18x7.5 +42; rear 18x8.5 +47;
tires: rear 255/40; front 225/40
Now my question is will this rub? Should I go with a 215/40?
Mar48 Mar 18, 2010 11:21 AM
you'll be fine with a 225, your rears will rub depending on your ride height, your fronts should be fine, you may need to modify the fender liner/ run slightly more camber but that's it. Rear all you would need is more camber.
I ran 18x9 + 55 all around with 225/255 and I had f -1.5/r -2.5 camber and cut our my fender liner in the front
elcoqui1 Mar 18, 2010 01:09 PM
I have a stock ride height, do you think it will rub in the rear? What size tires would I need so it doesn't rub?
1nate7 Mar 18, 2010 01:23 PM
If you don't want to take a chance on rubbing I'd run 215/40, 245/35.
elcoqui1 Mar 18, 2010 02:47 PM
Thanks for all the advice I might play it safe this time around and go with the 215/40, 245/35.
© 2026 MH Sub I, LLC dba Internet Brands
