Need Tire Options!
So as the title says. I am dropped currently and running 18x9.5 +50 all around (245/40/18 in front and 255/35/18 rears) with no issues. I want to go a bit more aggresive.
So I was thinking of getting 235 or 225 /40/18 fronts and 235 or 245/35/18 rears on the new ones... Thoughts? |
My thoughts:
1. Stick with +50 offset. Less worries and you can run wider tires without rubbing. 2. 245/35-18 up front would be a better fit up front, 245/40-18 are nearly an inch taller than stock, WRONG SIZE. If you go 245/255, they should both be 35 aspect ratio. Even 235's would be a better fit in 35 aspect ratio, but there's not a whole lotta selection in 235/35-18. 225/40-18 would be OK up front. |
Or, just put a 5-10mm spacer all around and run 245/35 x4.
Otherwise, agree with ZDan. 245/40/18 is SO tall up front :eek: |
Originally Posted by ZDan,Feb 2 2011, 04:56 PM
My thoughts:
1. Stick with +50 offset. Less worries and you can run wider tires without rubbing. 2. 245/35-18 up front would be a better fit up front, 245/40-18 are nearly an inch taller than stock, WRONG SIZE. If you go 245/255, they should both be 35 aspect ratio. Even 235's would be a better fit in 35 aspect ratio, but there's not a whole lotta selection in 235/35-18. 225/40-18 would be OK up front. 245/40 on a +50 is equalant to about 225-235/40 on a +35 offest no? the fronts Im not really worried about. As for the rears, I want to go as wide as possible without any problems. btw where in Provy are you from? I lived there for 4 years during school :)... Im there very very often... |
Originally Posted by DesiS2k,Feb 2 2011, 09:24 PM
The thing is I have 245/40 up front currently and I love the way it looks... Its beefy looking and not stretched.
However I would not mind running stretched tires on the new ones. 245/40 on a +50 is equalant to about 225-235/40 on a +35 offest no? the fronts Im not really worried about. As for the rears, I want to go as wide as possible without any problems. btw where in Provy are you from? I lived there for 4 years during school :)... Im there very very often... |
so what tire sizes would you suggest up front and rear without issues?
And def let you know next time im in Provy... |
Yeah, hit me up when you're in providence!
If you want "more aggressive", you might go 255/35-18 all around. If a taller 245/40-18 isn't rubbing up front, a shorter but wider 255/35 is probably going to clear, too. Maybe 255/35-18 fronts with 265/35-18 rears? No guarantees you wouldn't start to get rubbing in back though, with 10mm wider and also taller rears... What kinda tires are you considering? |
I would say the 245/35R18 and 255/35R18 rear would be the way that I would go. The 245/40R18 with the .7" difference can throw off the anti lock brakes.
blahhh...Went with a set of Work Kais 17x9 +44 :) I can get as beefy tires as I want now ;)
Thanks for all your help guys! Now just one more...for the rears, with the works, will a 245 45 setup fit or do you think I should get a 255 40 for a beefier look. Obviously the 265s are wider but froma side angle, the thicker side walls look beefier no? Once again...Thoughts? |
| All times are GMT -8. The time now is 11:23 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
