New alignment specs
Old Aug 29, 2012 | 11:15 AM
JUSTINTHECOASTIE's Avatar
Default New alignment specs
Hey guys and gals, here is my new alignment specs. I'm on GC sleeves on stock shocks(not slammed or anything) with AP2V1 rims. Tires are Hankook Evo v12s Front 225s Rears 255s.
Front
FL: -0.4 Camber FR:-0.6
6.9 Caster 7.4
-0.01 Toe 0.00
Front: Cross Camber:0.2
Cross Caster:-0.5
Cross SAI:-0.8
Total toe:-0.01
Rear
RL:-2.0 Camber RR:-2.1
0.26 Toe 0.21
Rear: Cross Camber:0.1
Total Toe:0.47
Thrust Angle:0.03
Thanks for looking
Old Aug 29, 2012 | 11:28 AM
ZDan's Avatar
Weakish front camber, a bit much rear toe...
Old Aug 29, 2012 | 11:34 AM
AndrewLin's Avatar
get that caster equal!
Old Aug 29, 2012 | 11:42 AM
FluKy15's Avatar
My thoughts too, not much done to the front side of the car while the rear is tweaked.
Old Aug 29, 2012 | 12:01 PM
Thanks for the feedback guys!
Could someone else with similar tire specs post their alignment specs?
Old Aug 29, 2012 | 01:34 PM
FluKy15's Avatar
You wouldnt like my alignment specs unless you go to the track often. I think you should half your rear camber, just my thoughts.
Caster 5.4 degrees right and left
toe .25 degrees out right and left on the front
1.8 camber on all 4 corners
0 toe rear
215 starspec front, 255 rs3 rear.
Old Aug 29, 2012 | 01:52 PM
unlewser's Avatar
I just got an alignment by science of speed. I am low with rpf1 17x9 +45 235/40/17 front and 255/40/17 rear
Front
Camber
1.5 1.5
Toe
0.0 0.0
Caster
6 6
Rear
Camber
2.7 2.8
Toe
.24 .24
Old Aug 29, 2012 | 02:49 PM
FluKy15's Avatar
Front
Camber
1.5 1.5
Toe
0.0 0.0
Caster
6 6
Rear
Camber
2.7 2.8
Toe
.24 .24
If you track, you want more front camber, less rear camber.
Old Sep 20, 2012 | 09:55 PM
Toneezy's Avatar
Did you guys need a camber kit for the front? I was maxed at -1.4. Kind've want to run more negative camber for the next track day.
SPLNDID
Mar 14, 2010 02:19 PM
irock aypee one
Dec 16, 2006 11:46 AM
onani
Nov 23, 2005 03:23 PM
RazorV3
Nov 14, 2004 08:18 AM
