non staggered setups
Old Jan 31, 2011 | 02:20 PM
Trent06's Avatar
Default non staggered setups
what is the purpose of running a non staggered setup?
Old Jan 31, 2011 | 02:35 PM
chetly's Avatar
more front grip.
Old Jan 31, 2011 | 09:32 PM
BowlofRice's Avatar
Does one need supporting suspension mods to run a square setup? I've read a bigger front sway bar but same could be said for a staggered setup as well.
Old Feb 1, 2011 | 07:50 AM
aCab's Avatar
going to a non-staggered setup should make the car oversteer more. You have more front grip than the staggered set up, so to even it out, a bigger bar is usually put on. I run 255 all around on my AP2 with a 32mm cusco front bar and no rear sway and its pretty neutral.
Old Feb 1, 2011 | 08:08 AM
RedCelica's Avatar
^^^no rear sway?! For real?
Old Feb 1, 2011 | 08:16 AM
aCab's Avatar
fur real
look around, there are quite a few people running without a rear.
Old Feb 1, 2011 | 08:23 AM
RedCelica's Avatar
doesnt that make the rear a little "loose?"
Old Feb 1, 2011 | 08:53 AM
chetly's Avatar
I'm not running a rear bar either. Running a Saner bar on medium and rear bar made the car oversteer, taking rear bar off made it push, so I went up 100lbs on the rear spring rate. So far, so good.
Old Feb 1, 2011 | 09:15 AM
chuhsi's Avatar
Generally a combination of more front bar, less rear bar, stiffer front springs, and alignment changes
Old Feb 1, 2011 | 12:31 PM
RedCelica's Avatar
very interesting...good info guys
