Offset!
Is there any way that a +40 offset work for an 05 s2000 (rear)?
Maybe with a 17X7 and a 215/45R17 but not with a 17X8 and a 245/40R17.
At the rear its 17x8.5
yeah you failed to mention the size of the wheels.
So there is now way that this will fit even with fender rolling? Damn! they tricked me...... they said that it will fit, so I went ahead and got them. Now, every road dips has a sound effecting my rear. I looked at the tires and I saw a line going around the outside of the tire. I still have my stock suspension.... What can I do about this? They said over the phone that it should fit, I really dont know what to do. Probably just complain a little bit harder, I guess.......
fender rolling will give u about 10mm the most. so, now your offset would be aroun +50 with the fender rolled. 17x8.5 +50 most likely you'll still rub if you lower your car. I suggest get negative camber and fender rolled.
Originally Posted by x s2k x,Dec 22 2005, 12:31 PM
So there is now way that this will fit even with fender rolling? Damn! they tricked me...... At the wheel warehouse they said that it will fit, so I went ahead and got them. Now, every road dips has a sound effecting my rear. I looked at the tires and I saw a line going around the outside of the tire. I still have my stock suspension.... What can I do about this? They said over the phone that it should fit, I really dont know what to do. Probably just complain a little bit harder, I guess.......
With that width and diameter of rim, you need at least a 60mm offset. |
Just got done talking to them and said that they are going to fender roll the rears. I still dont think its going to work.........
Pare... try to exchange it with wheels with proper offset. +55 and above for 17x8.5
| All times are GMT -8. The time now is 04:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
