Offset Qeustion?
no im not asking whats the best offset to use, i did search and found soem usefull info, but didnt find a post saying that if you use this offset on this wide of a wheel this will happen,
like what whould be the difference like if you used a 17x7.5 wide wheel in the front and what whould the difference be between +48 offset +50 and so on, same for the rear, a 17x8.5 with a +50 offset or +63 and so on, im just tryin to figure out what will happen if you use a certain offset, like is 17x7.5 +40 to much for the front
any help whould be great
thanks guys
thanks guys
Here are a couple of charts/calculators to help you out. Hope they explain it better than trying to do so verbally:
http://toy4two.home.mindspring.com/offset.html
http://www.midatlanticmotorsport.com/wheel_diag.htm
