offset question
is this going to be fine?..............
16x7 35+ front 16x8 35+ rear or will i need wheels spacers ? thanks guys! |
No, and... No, and BTW, wheel spacers will decrease your offset. (Factory is +55 and +65)
so they wont fit at all???????????????????????
they fit, but fender rolling is required for maximum clearance. that front is equivalent to the the sw388 that clears the spoon caliper and the rear is 10mm out fron the sw388 rear.
i made a mistake the real offset is 38+ for front and rear...does that make it a bit easier?..... i mis-read the numbers sorry guys
it is a little easier by 3mm
You can get them on. But you will have to cut your rear fender tabs, roll all your fenders, and run additional negative camber to avoid rubbing.
the 50+ offset gets you into the safer range.
38mm is not great but its aggressive lol. |
Hhow do i set the negative camber? (never done it) thanks guys!
i like it flushed..... |
| All times are GMT -8. The time now is 07:29 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
