Ok just to make sure....
I was looking around on ebay for some rims for my 2003 s2000, and i found one that i kind of like. (here is the link ebay)
I was wondering if they would fit and what kind of tires i would need.
These are the specs:
Name : STERN - ST1 FACE-III BEAST
Bolt pattern : 5x114.3
Size : 18x8 Front & 18x9.5 Rear (WIDE LOOK)
Offset : 48mm Front & 48mm Rear
Lip Size : 2"F & 3"R
They also have the exact same rims but with a narrower back,
Size : 18x8 Front & 18x8.5 Rear
Offset : 48mm Front & 45mm Rear
Lip Size : 2"F & 2.5"R
I would like to purchase these rims but i need to make sure that i can find tires for them and that they won't cost me 1000$ a pop :-)
Additionally, according to my research, these rims should fit, but i need to make sure before i shell out 900$ for them.
Your help would be much appreciated.
Man this is insane.... ok so what size rims can i get without rolling the fenders and doing a tab relocation?
I would like the get 18" preferably....
Thank you so much for your help, it just saved me 900$ :-)
Dave
Dave
You want to be in a 55 mm offset or higher depending on the width of the wheel and the size of the tire you choose. In a 8" wide wheel you can run up to a 45mm offset with a 245/40R17.
If i can help let me know.
I have had those wheels personally, and they do stick out a bit in back. I ran the 9.5s in back, but the rubbing wasn't as bad as one might think. I ran them for about 8 mos or so. In fact, if you roll your fenders appropriately and do a bumper tab relocation, you probably won't have much of a problem. Right before I got rid of those wheels, I relocated the tab, and the rubbing ceased altogether.
Oh yes, I ran 265-35-18 in back with pretty much stock alignment specs. I will add in some pics if I can find some.
Like some others said... save yourself the headache and keep looking.
