Once again
We need to know what size is your rim and what is its offset in order to determine if it will rub or not.
235 will be best to eliminate rubbing but is a poor choice from a performance standpoint. Going wider will be better but can't say if it will fit without offsets.
EDIT - if these are the same rims you were asking about in a nearly identical thread you posted yesterday (8.5 +47)
--> https://www.s2ki.com/forums/index.php?showtopic=423491
245 should fit fine, if not adding negative will get you there.
Sorry yes, it is a simuliar thread. It just that not many reply thats why i decide to put another one up to get a better idea. I just don't want to purchase the tire and have the same problem again. Thanx for your reply DerrS2K. Appreciated your opinion.
Offset is +47 rear.
Offset is +47 rear.
