S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Once again (https://www.s2ki.com/forums/wheels-tires-56/once-again-423762/)
geovong Sep 20, 2006 12:56 PM
Once again
What tire brand and what size is best from rubbing for a rear Ce28?
(1" drop with camber kit ready to be install)
235/40/18x8.5 or 245/35/18x8.5 ------>what you reccamend?
DerrS2K Sep 20, 2006 12:59 PM
We need to know what size is your rim and what is its offset in order to determine if it will rub or not.
235 will be best to eliminate rubbing but is a poor choice from a performance standpoint. Going wider will be better but can't say if it will fit without offsets.
DerrS2K Sep 20, 2006 01:03 PM
EDIT - if these are the same rims you were asking about in a nearly identical thread you posted yesterday (8.5 +47)
--> https://www.s2ki.com/forums/index.php?showtopic=423491
245 should fit fine, if not adding negative will get you there.
geovong Sep 20, 2006 04:04 PM
Sorry yes, it is a simuliar thread. It just that not many reply thats why i decide to put another one up to get a better idea. I just don't want to purchase the tire and have the same problem again. Thanx for your reply DerrS2K. Appreciated your opinion.
Offset is +47 rear.
racerfan Sep 20, 2006 04:46 PM
225 40 18 front
245 35 18 rear or a 255 35 18 rear
if you run the right alignment it should be fine.
© 2026 MH Sub I, LLC dba Internet Brands
