Which one should I get...???
Old Dec 26, 2019 | 11:36 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Originally Posted by methduck
If you're only going to be swapping the rear tires side to side, that won't help anything, in order to rotate the tires properly you need to rotate front to back and back to front, otherwise it's pointless to just rotate them side to side.
the inside part of the tires will always be on the inside if you're swapping side to side.
Also the majority of performance tires nowadays are directional
Switching from side to side,moves the worn inside to the outside.
Of course,you have to take them off the wheels,and rebalance.
So,you end up with the worn part of the tire being now on the outside,and the not so worn part on the inside.
Old Dec 27, 2019 | 02:19 PM
And,I read that PS4 were squirmy,due to soft sidewalls.
Old Dec 27, 2019 | 09:10 PM
Bullwings's Avatar
Either run less camber because you're not making use of the camber, or take corners harder so you make use of the camber you've aligned for.
Mounting, dismounting, and rebalancing tires that realistically have a lifespan of less than 30k miles is a waste.
You have either selected the wrong tire, the wrong alignment, or both for your given application.
Old Dec 28, 2019 | 06:26 AM
Chuck S's Avatar
No one rotates tires by removing and remounting. Not unless they have money and time to burn. Driving a S2000 on tires rated to last 30K miles gives up handling for the sake of a few dollars. My tires would age-out long before 30K miles anyway. I'm content to just get good performance tires every 3 or 4 years.
Asymmetric tires like my Bridgestone S-04s -- and their wheels -- can easily be swapped side to side but I've never seen the need. Tires develop a wear pattern based on their direction of rotation and doing this may increase wear by changing it. And, of course, directional tires have to be dismounted and remounted to swap from side to side.
-- Chuck
Old Dec 30, 2019 | 11:48 AM
So,wich one has the stiffest sidewall.???
My bet is on BFG.
Old Dec 30, 2019 | 03:40 PM
Bama Dave's Avatar
My bet is on BFG.
The Bridgestone RE-71Rs
Old Dec 30, 2019 | 03:44 PM
EOE's Avatar
EOE
I heard V12 were a hype. I recall everyone buying them then I hear it being an OK tire if that. I’d research a bit more.
Old Dec 30, 2019 | 04:26 PM
And you get 6000 miles out of them.
Old Dec 30, 2019 | 04:27 PM
Going for BFG.
turbo8765
Mar 3, 2019 06:24 AM
Leong3
Cars for Sale
Jan 15, 2019 12:24 AM
Dan Fendick
Jul 21, 2018 04:18 AM
Fmj03
Jul 12, 2017 11:57 AM
