People that have switched to 245/45/16
Originally Posted by ZDan,May 24 2007, 09:24 AM
The original 225/50-16 S02 (which measures wider at the tread than most 225s) was designed for a 6 -8" rim.
Most 245/45-16 tires are designed for a 7.5" to 9" rim.
So basically, though you're getting the same "tread width" vs original S02's in getting non-OEM 245/45-16s, you are getting a tire designed for a wider rim.
I don't think the 245/45-16 size is any more "correct" than non-OEM 225/50-16s, and perhaps it is less so.
Originally Posted by NFRGUAMBOMB,May 24 2007, 01:10 AM
i think its the soft side wall of the toyo...
I only replaced the rears. The fronts are still stock s02s, because they still have plenty of tread. I've done this before on other cars and never had any problems having different brand front/rear tires.
Originally Posted by Jay2000,May 24 2007, 06:32 AM
Also check air pressure, When I switched to the re750 it felt unstable until about 600 miles or so and the tech put 36 lbs in them. I ran 34 in the back and 32 up front and they settled down.
Originally Posted by NFRGUAMBOMB,May 24 2007, 08:34 AM
245/45-16 tires are (generally) designed for 7.5" - 9" wide rims. The stock AP1 rear rim is at the bare minimum width allowed for this tire size. So the tire is pinched a bit. Less than ideal for lateral stability.
Had the tire pressure checked and they were both at 33psi. Also had the wheels rebalanced. Haven't had a chance to take it on the highway, but I will update when I do to see if its still doing it. If yes, I will get an alignment.
It's also worth mentioning that brand new tires with full tread depth will have a lot more tread squirminess than worn tires, so that could be part of the perceived problem here.
Full tire tread always feel squirmy to me, then I get used to it, and it imperceptably improves as the tread wears down, then it pops up again with new tires - the circle of life
I went to 255 to 245 on the rear on 18's
Benefits
The tire now sits a little rounder on the rim and not so square. therefore I Have a little more tire surface grip.
Tire will wear a little less on the inside.
Negative side.
I notice the back is a little happier than before.
My current tires. Not sure if because the size or the wall softness (hankook ventus) did not protect my wheel on a very stupid pot hole damaging the wheel lip.
This didn't happen on my previous tires (falkens)
I will switch back to 255 on the next tire change.
Benefits
Negative side.
watch out crazy lady attack in this thread - a stock tire isnt a 245 width and it's not comparable to any other tires stated specs. different tires are different tires / end
the ra1 is a lightweight circuit spec dot legal tire that uses fiberglass for reinforcement on many models in lieu of or in a addition to steel, it likes high static camber to perform due to it's profile and tread pattern - over 2 degrees negative on a civic and I'd imagine 3 degrees at least on the s2000 and it's one of the few tires that last longer and perform better when you shave off half there tread. Also it tends to be a little more giving to survive under heavy track use.
What your probably experiencing is too much sidewall flex, too little camber. Yes it's too wide for a 7.5inch wheel you can add some psi,more camber and shave the tread to 4/32nds to fix it or go with a 225 size.
NightShark
Feb 20, 2008 08:19 PM
