Question
Hey,I just picked up an S... It has Stoptech BigBrake Kit.... and has 18in wheels on them. I want to kno if i can fix the stock wheels back on or can get go with 17in aftermarket wheels with wha kinda offset... Thanks
you can get 17 inch aftermarket wheels, but its not the offset that matters. it's the design of the wheel. you could have two wheels with the same offset, but one will fit, the other will not. not all wheels will fit the bbk, you have to look around for info on your specific wheel, or if you have access to the wheel, test fit it
I used this link to get a good idea. If all else fails find a rim on there you like that you know will clear.
https://www.s2ki.com/forums/index.ph...ic=338881&st=0
00S2K01S4
Dec 10, 2002 12:37 PM
