Question on Hubcentric ring
Hi,
I bought ASA AR1 couple months ago and when shop was installing them, they called me that hubcentric rings weren't fitting on the hub, so i went there to look at. Front hubcentric rings were thicker than rear yet wasn't small enough to fit on the hub but was just wobbling. Rear was thiner and also too big for the hub, so i switched front and back which made medium fitment (still loose though) on the rear and bascially no contact between hub and centric on the front. Would this cause any problem? and those hubcentric rings were from tirerack with the wheels. I'm just worried it's going to cause any problem since i hear some noise from wheels these days. But again, i asked this question before and someone told me that many people just run aftermarket wheels without hubcentric rings due to irregular size of hub on S. Thanks. |
The S2000 seems be a car that can do without the rings. I'm not saying you should leave them out on purpose but they tend to be OK without them.
i see. that makes me feel better!
thanks! |
| All times are GMT -8. The time now is 06:39 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
