S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   questions about offsets. (https://www.s2ki.com/forums/wheels-tires-56/questions-about-offsets-110018/)
LIL RAJA Mar 12, 2003 04:24 AM
I currently have the VOLK GT-7s with +50mm offset. I am looking into possibly getting custom wheels made with the best offset.
for wheel size 18*8 and 18*9 what would be the best offset or better yet the correct offset and what size tires do you guys suggest?
thanks!
LIL Raja
Jim@tirerack Mar 12, 2003 05:36 AM
There is no correct offset only offsets that work on the car. In the 18" look for around 50mm front and 62 rear.
Jim
LIL RAJA Mar 12, 2003 07:17 AM
Jim,
so 50mm in the front and 62 in the back with 18x9 will work?
what size tires would you run? and do you have s03 in 18s & 19s?
my friend is looking for 19s for him m3. please help.
PM me
Raja
FF2Skip Mar 12, 2003 12:33 PM
HOLY COW! :yikes:
Another set of rims? I'll take the hand-me-downs!!! :D
WRS2K Mar 12, 2003 12:34 PM
There are offsets that work on the car better than others and all 18" rims that Tirerack sells have offsets that don't work better than what you could get should you go custom.
For the rims you spec-ed out, you're going to want ~55+ fronts and 65+ rears and you'll be golden. That way, you can run the widest tires appropriate for your rim width (go to Jim for these types of recommendations / would guess 225 fronts and perhaps 265-275 rears?) without worries of rubbing at full compression, at full lock, at stock height or lowered a crap load (should you choose to go that route, but ~1-1.5" is a safe bet all around).
Awesome to see that finally someone is spending money on rims that will fit properly! Good luck my friend. :)
PS - As for your friend's M3, assuming it's the E46... there's nothing better than the BBS LMs... and he can get those from Tirerack.
© 2026 MH Sub I, LLC dba Internet Brands
