S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Rear offset? (https://www.s2ki.com/forums/wheels-tires-56/rear-offset-331982/)
spoiled@21 Oct 24, 2005 04:32 PM
Rear offset?
There are always the questions about brakes and front offsets but what is the lowest off set you could run with a slight drop (1.2-1.5in) in rear wheels? 9in wide is what I am looking at.
Thanks,
Alex
spa-zz Oct 24, 2005 05:41 PM
Around 52 to 55, depending on camber. Might need a fender roll.
Jim@tirerack Oct 25, 2005 11:55 AM
With the 9" wide you would want to be around 55 to 62 with the higher the offset the better.
© 2026 MH Sub I, LLC dba Internet Brands
