Rear Wheel Alignment?
In hopes of improving tire life, I would like to "de-tune" the rear wheel alignment a bit. I think I want to take the Camber down to +0.5 degree and the Toe-in to 0 degrees. I have these questions:
1. why or why not do this? 2. If I do, what's the right, corresponding Caster setting? (OEM is 5.75-6.25 degrees) |
The thing I recommend would be to run Honda's lowest recommended toe in setting for the rear. If you are gettin uneven wear on the inside rear then less negative camber.
Jim |
| All times are GMT -8. The time now is 03:04 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
