Rear Wheel Rubs
Hello All,
I have a set of CE28's Front: 18x7.5 +50 and Rear: 18x8.5 +47. What is the recommended camber adjustment that needs to be done to make the rear not rub? I am also rolling the fenders, but I know that it might rub the rear still without camber. The goal is to get the right camber without doing to much.
Any help will be great! Thanks
Well right now I am not running suspension. I plan on learning the car first before doing that. Right now it only rubs when driven aggressively. I am running CE28's Front: 18x7.5 +50 and Rear: 18x8.5 +47. Tires are Front: 225 40 18 and the Rears: 255 35 18. So what do you think.
Id probably do a combination that way you dont have to get too extreme with either the camber or the bodywork
Another option would be putting a 245 on the rear.
that will work
