Replacement size for AP1 stock tires
:thumbup: Hi there, i know the topic been debated to death but here we go again.
Story: I am replacing my stock tires on my ap1 wheel soon, I have stock height and stock everything. I am thinking of getting aftermarket tires but i want them to be in stock size, i am not going for the lower profile because i don't need to clear nothing with stock height. I am thinking of getting Kumho SPT, BFgoodwich G-force sport or Falken 615 So the stock tires' size are 205/55/16 Front 225/45/16 Rear So i will need 205/55/16 Front(aftermarket) 245/50/16 Rear(aftermaket) RIGHT? for the rear tires, is it 50 or 45 series? What's deal? thanks s2ki |
You need 245/45/16 for the rear. There's a whole thread stickied at the top about it.
https://www.s2ki.com/forums/showthread.php?threadid=48572 |
https://www.s2ki.com/forums/showthread.php?threadid=48572 btw will the 45 series match the 50 series in tire wall height? or the over all height will be shorten? |
A 245/50R16 will be taller sidewall than 245/45R16...The 45 and 50 series are actually based off percentages of the width. Example....
A 205/50/16 will have a smaller sidewall than a 245/50/16. This is why you will notice the 205/55 up from and the 225/45 in the rear, yet the sidewalls should look relatively the same height. Hope that helps. |
So, a 205/55/16 tire has a sidewall that is 55% of the tread width (or 205 in this case) or about 137.5mm. |
Great help
S2ki= :thumbup: |
Ok where are you finding SPT's in 245/45/16 ? I can only find them in 245/50/16, and am a bit confused on which size to go with since they're not available in 245/45...
ty |
| All times are GMT -8. The time now is 10:21 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
