rims for track use
Old Jul 5, 2012 | 11:19 PM
kotsapas's Avatar
Default rims for track use
Hey guys!
Found some really good deal locally for some rims that i plan on using for the track only..
Will these fit on my s2000 without rubbing and without any modifications?
Is the wheel pattern correct?
Front
Diameter : 17"
Width : 8jj
Offset: +35
PCD: 5x114.3 & 4x114.3
Tyre:Toyo R1R 225/45/17 (Nearly brand new only 100khm)
Rear
Diameter : 17"
Width : 9jj
Offset: +35
Tyre: Toyo R888 255/40/17
Thanks guys!
Old Jul 6, 2012 | 01:21 AM
MaxGeek's Avatar
The wheel forum is a better place for this thread. They can give you the best advice.
https://www.s2ki.com/s2000/forum/56-...the-tire-rack/
The offset on the wheels are too low for the S2000, they will stick out beyond the fenders.
Typically 8" fronts need around a +50mm offset and 9" rears need around a 60mm offset.
Old Jul 6, 2012 | 01:38 AM
kotsapas's Avatar
ohh you are probably right..
i will fit them on before buying just in case..but most probably the offset will cause rubbing...
I forgot to mention..i do not have any fender rolled
Old Jul 6, 2012 | 02:43 PM
Breaking Point's Avatar
Why not a +45? Seems to be popular choice
Old Jul 6, 2012 | 09:24 PM
kotsapas's Avatar
cause i found a really good deal locally..:/
Old Jul 7, 2012 | 08:46 AM
dc2-2-ap1's Avatar
No, they will not fit without a fender roll and slight pull. Some will tell you they will fit but they WON'T fit without modification (unless you want to downgrade tire sizes to 205 in the front / 225 in the rear and run between a -3 and -4 degrees of camber in the rear- which is pointless since they are track wheels)
I would highly recommend passing on the deal.
Old Jul 7, 2012 | 09:56 AM
kotsapas's Avatar
thanks very much for sharing your wisdom..
seems that i will have to pass..its a shame really
Old Jul 7, 2012 | 05:14 PM
davidc1's Avatar
Not to mention completely mismatched tires front and rear.
An average tire for the front, and one of the grippiest tires for the rear. I would n't track it with that mismatch.
Old Jul 7, 2012 | 10:19 PM
kotsapas's Avatar
R1R are one of the best performing (radial) tires!
its very popular here in my country..
there are some pretty good laptimes done with those tires
i would compare them with neova ad08..similar gripy tires
Old Jul 7, 2012 | 11:16 PM
davidc1's Avatar
Lots of tire tests, and testimonials from drivers have shown that while the R1R is a good tire, it's pretty much at the bottom of the rung for this category of tires. No offense, but I don't think anybody here thinks they are anywhere near the performance level of the AD08. Or the RS-3, or the StarSpec, etc.
