RO_JA R2-5
Old Mar 9, 2006 | 01:57 PM
SPFSkyline's Avatar
Thumbs up RO_JA R2-5
Ok the offset are not perfect, but are they close enough that they wouldn't rub or stick out?
Front: 18 x 7.5 +47 (that's perfect right?)
Rear: 18 x 8 +37 or +47 (either close enough? One better than other?)
Here is a pic RO_JA R2-5 Mercury Carbon Black:
Old Mar 9, 2006 | 02:08 PM
neveronlines2k's Avatar
Front will be ok.
if its an 18x8 +37 in the rear it will rub. +47 would be better, but not Ideal.
Old Mar 9, 2006 | 02:20 PM
SPFSkyline's Avatar
ok well if i did get the +47 in the rear would it stick out or look wierd (in your opinion of course)?
Would it look anything like this?
https://www.s2ki.com/forums/index.php?showtopic=279239
Old Mar 9, 2006 | 02:59 PM
with the +47 it shouldn't be too bad since the wheels is only 8". It may stick out like the pick in the link or a little less. You will just notice more water on the car after going through puddles.
If your car is lowered more than an inch you may have rubbing issues(depending on what size tires you run).
Old Mar 9, 2006 | 03:26 PM
spa-zz's Avatar
No, not "perfect." That's about the minimum offset that will fit on the front and still use a reasonable tire. You'll need to stay at about 215 or below in tire width to keep from rubbing.
18x8 +40 is just about flush with the fender, so you are in pretty good shape with a +47. You should be able to squeeze a 245 in the rear.
Cheers.
Seven11
Dec 11, 2013 08:14 PM
I.tamdinh
Aug 8, 2012 09:46 PM
rioyellows2k
Jun 11, 2007 08:47 PM
Xpresso2am
Jun 28, 2005 01:04 PM
dxlst
May 15, 2003 03:20 PM
