S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   rota slip stream fitment +48 offset (https://www.s2ki.com/forums/wheels-tires-56/rota-slip-stream-fitment-48-offset-727366/)
c32b Aug 31, 2009 10:16 PM
Hi folks,
planning to buy rota slipstreams 17 x 8j front +48, 17 8.5 j rear +48.
tyres to be fitted are 215/45/17 F and 245/40/17R.
my suspension is fully stock, with camber of -1.5 F and -2.5R.
according to the wheel fitment guide this size is safe but says i may need a roll/tab replacement
Anyone know if i definitely need an fender roll or tab repositioning? My hope is i do not need to touch the fenders.
s2k dre Aug 31, 2009 10:30 PM
The fronts will be good, the rears u should clear, ur only 17mm more than stock fitment but u got to mount thr wheels and see.
c32b Aug 31, 2009 10:57 PM
i'm really hoping to know before i order the rims. dont wanna spend unncessary cash to get a rim that dont fit right... a bit worried that the rears will rub?
s2k dre Sep 1, 2009 12:39 AM
Most of the time u can run 15mm spacers on the oem ap2 wheels and not rub. Depends on camber! -2.5 should be more than enough.
foxy_s2k Sep 2, 2009 12:48 AM
I have those exact rims in those exact dimensions, on my stock ride height S. Even on very bumpy roads (note I am in Greece ;)), I've had no problems whatsoever, you do not need to touch the fenders or use spacers, or even change the camber.
zacs2K Sep 2, 2009 12:07 PM
i have your exact same setup op, lowered on espelirs, no rubbing and no fender rolling, no spacers
© 2026 MH Sub I, LLC dba Internet Brands
