S03's VS S02's
I'm thinking about going with the S03's to replace my stock s02's. I have a couple of questions:
1. Will this tire wear better than the S02?
2. Will this tire handle better then the S02? (Wet/Dry)?
3. Does the S03 have the same sizing attributes as the S02? Do I stick with the same sizing, or do I need to go with the 205/55/16 front and 245/45/16 rear that is recommended for non-OEM tires?
Your help is appreciated!
The S03 will normally get longer tread life and better wet traction but the S02 is the better handling tire. For the S03 you would go to the 205/55R16 front and 245/45R16 in the rear.
If I can help just give me a call.
Thank you
Jim 877-522-8473-364
Thank you
mojo-
1. Personally I have found that the s02's will last longer than s03's. I got about 22k/15k (front/rear) with my s02's and only about 13k/8k with my s03's.
2. The s03's will handle a lot better in the rain, I haven't noticed too much difference on dry pavement (but I don't drive too hard).
3. What Jim said.
3. What Jim said.
Tini
Aug 5, 2002 10:34 PM
