S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   S2000 Aggressive Offset (https://www.s2ki.com/forums/wheels-tires-56/s2000-aggressive-offset-836703/)
RNGUYENYO! Dec 23, 2010 12:20 PM
Hey everyone, I really want an s2000, I want it to be hellaflush!
I wanna run on work meister s1's, I am thinking 17 or 18 inch wheels, 8.5 wide front and 9.5 wide rear, with a +30 offset all around or even less, I want to stretch the tires but not so much, just some. Do you guys know how much negative camber this will take, how much fender rolling, or if it will even work, what size tires to run if I stretch them a little? Thanks in Advance!
JDMQuip Dec 23, 2010 05:44 PM
:faint: :egads:
ZDan Dec 23, 2010 07:26 PM
This is just too cute and precious for words!
:LOL:
Know this: Whatever wheel width and tire width you go with for +30 offset wheels, you could've gone an inch wider on wheels and three sizes wider (30mm) on tires with +43 offset while having the same amount of "hellaflushness".
Don't fixate on OFFSET alone. Nothing looks much worse than an otherwise proper sports car on skinny wheels/tires that are shoved way outboard.
Carbon Blue Dec 24, 2010 01:11 AM
hellastupid
EOE Dec 26, 2010 09:29 PM
Originally Posted by 2ndTimeAround,Dec 24 2010, 02:13 AM
Go F up a Civic
:LOL: :thumbup:
TRD_Celica Dec 26, 2010 09:40 PM
Before asking any of these questions, go to a hellflush forum and you will learn a lot! Also check out the stance thread in the gallery, some people post up their specs and you should go from there
Euroflavor Dec 26, 2010 09:55 PM
as stated. offset is half the battle. width is a huge factor as well
chViETnk Dec 27, 2010 12:43 AM
lol
Jim@tirerack Dec 27, 2010 01:40 PM
Every tire is going to be slightly different from one to the next. There is no way somebody can tell you how much you will need to roll your fenders. You are going to need more that a fender lip roll and a lot of negative camber to make this work is all I can say.
clarkster009 Dec 28, 2010 08:23 AM
Originally Posted by 2ndTimeAround,Dec 23 2010, 11:13 PM
Go F up a Civic
:iagree: :zip: :cry:
Dumbasses that come out of the woodwork when prices hit $10-12K
© 2026 MH Sub I, LLC dba Internet Brands
