s2000 stance help
So I'm in the process of buying rims and im trying to make my s2000 Go from this
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
To this ... what do i need to do?
Thanks for your help in advance. =)
May i ask why you bought the CR if you werent going to track it and wanted to make it hellaflush? Im just wondering because you could saved yourself a ton and had the same look.
Those tires arent wide looking, the wheels are though. Pretty sure that person has flared fenders which can get real expensive depending on amount of flare you want. He is also running A TON of camber, has really aggressive wheels and skinny ass tires. So thatd what you need. As well as being very low
find some rims with +35 offsets, get your fenders rolled and buy a set of coilovers...
hellaflush does not = meaty tires
You can ether have aggressive figment with stretched tires or meaty tires on rims in a more s2k friendly offset.
The pic of highwaystar's car you posted above was an example of a Hellaflush setup with very stretched tires. Here is what meaty tires looks like, 255s up front and 275s in the rear.
ohh ok i juss like how the tires stick out i think it looks nice you know. and what do you mean by more friendly offset.
And thanks for the other picture
Just because the tires "look" meaty doesn't mean they are...I'm willing to bet those are 245s on the back of that S, which is 10mm SMALLER than stock (for you). There is absolutely no need for that...unless you bought the CR because you like the wing.
