S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Should I go bigger? (https://www.s2ki.com/forums/wheels-tires-56/should-i-go-bigger-863638/)
Jrse7en Apr 28, 2011 10:56 AM
Should I go bigger?
:hello: I'm ordering 4 Hankook RS-3's tomorrow but I don't know which size to order. I think I have AP2V3 wheels (Stock 2008). I want to go with the bigger size if they are not harder to mount. The price isn't much different. Can I go with the bigger sizes without any hassle? I also am getting Eibach Pro-Kit springs installed next week. Would their be any issues at all with rubbing with a wider tire or anything I should know beforehand?
JonBoy Apr 28, 2011 12:15 PM
I ran 225 / 255 and it felt great. Very nice overall balance and slightly improved weighting of the steering.
The CR does 215 / 255, if you want to stick to "stock" sizing. Either way, you shouldn't rub on anything.
Jrse7en Apr 29, 2011 04:17 AM
I'm gonna order my tires now. 215/255.
Marekv Apr 29, 2011 06:42 AM
I went with CR sizes also, 215/255, just placed my tirerack order on Wednesday. Different tire though.
Jrse7en Apr 29, 2011 06:46 AM
Well actually the 225's are about $10 cheaper than the 215's. I read that 255's are fine for the rear but haven't read a confirmation on the 225's on the fronts.
Chris S May 8, 2011 09:10 PM
I'm running 225/255 on my '08, no rubbing problems even w/ it lowered quite a bit.
dwight May 8, 2011 10:44 PM
Do you change your tire pressure with the wider tires?
Jim@tirerack May 9, 2011 05:48 AM
You can run either 215/45R17 or 225/45R17 on the front and you would run the OE tire pressure. If I can help with anything let me know.
Chris S May 9, 2011 06:14 AM
Originally Posted by dwight (Post 20553221)
Originally Posted by Chris S' timestamp='1304917810' post='20553036
[quote name='Jrse7en' timestamp='1304088376' post='20520746']
[/quote]
I bought the car 5/1, and haven't checked the tire pressure yet. I even hit the track yesterday, and it was great as is, no adjustments needed.
© 2026 MH Sub I, LLC dba Internet Brands
