Silly Question - Tire Pressure.
Hi Guys
I have an AP1 with AP2 wheels on it and Potenza tyres: Front - 215/45R17 Back - 245/40R17 What is the correct tyre pressure for front and back? I know to do it cold, but not to sure what to put in? Thanks |
It should say somewhere on the tirewall.....I know the stock RE050 tires are supposed to be at 32psi.
Pressure on the tire sidewall is max pressure the tire is rated for. AP2s run 32psi all around.
DURRRR :ashamed:
at least I got the psi right. |
Either way, I agree with Angelus1243. 32psi. Anywhere between 30-33 should be fine for normal driving. |
Originally Posted by __redruM,Mar 7 2008, 10:27 AM
Where'd you get the spelling tyre for tire? Is it the english or french spelling?
never knew that.
Originally Posted by nzouk77,Mar 7 2008, 08:26 AM
It will be on the door jam, not the tirewall.
Thanks.... the reason I didnt check the door jam is because I have the AP1, which had 16's standard.... I have the 17's...
| All times are GMT -8. The time now is 10:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
