SPACERS AND LUG NUTS
Old Apr 16, 2008 | 07:58 PM
astig2k's Avatar
Thumbs up SPACERS AND LUG NUTS
what is the largest spacer size that can be used with stock length studs? and how many turns "minimum" should you have with the lug nuts in order to be able to keep it secure and safe to drive?
Old Apr 16, 2008 | 08:15 PM
Sinji's Avatar
the max I would go with is 5mm. usually you would want about 7 full turns on the lugnut. there are spacers like project kics that you can bolt on to the original studs and it will come with its own studs:
Old Apr 16, 2008 | 08:44 PM
astig2k's Avatar
i purchased 5mm H&R spacers and i got about 4 turns with the lugs. how safe is it to drive around with 4?
Old Apr 17, 2008 | 04:53 AM
ZDan's Avatar
6 turns bare minimum. That's 9mm/0.75 diameters of thread engagement.
4 turns? Only 4 threads/6mm/half a diameter thread engagement.
I wouldn't.
Old Apr 17, 2008 | 08:05 AM
daverx7's Avatar
For autocrossing, I use the 5mm spacers and wasn't comfortable using the OEM studs, so I ended up using the studs that came with the spacers.
BTW, replacing the studs it is not as easy of a task as it should be. ugh.
-D
Old Apr 17, 2008 | 10:25 AM
babowc's Avatar
What's the hub sizing for S2000?
I tried on some 25mm spacers I had laying around the house and the S2k hub bore is tinyyyyy.
With any bolt-on spacers you're gonna want to run hubrings.
Old Apr 17, 2008 | 10:55 AM
Sinji's Avatar
73mm front and 65mm rear
Old Apr 17, 2008 | 11:13 AM
babowc's Avatar
Cool beans.
btw, s2k thread/pitch is 1.5x12, right?
My 1.25x12 lugnuts wouldn't fit
Old Apr 17, 2008 | 11:44 AM
HUYS2200's Avatar
Originally Posted by babowc,Apr 17 2008, 12:13 PM
Cool beans.
Yes.
12x1.25 are for Nissan, Subaru, Infiniti.
Old Apr 17, 2008 | 01:42 PM
AP2's Avatar
AP2
the minimum i would do would be the diameter of the stud. for example, if the stud is 12mm in diameter, the lug would have to go at least 12mm onto the stud.
