SSR Professor 18"
Old Dec 30, 2011 | 12:02 AM
panta's Avatar
Default SSR Professor 18"
Hi all !
I found a nice set of SSR SP1 in 18 ... I'd like to know if they'll fit on my S.
Size are :
18x8.5 +30
18x9.5 +43
What do you think ???
I also got an AP racing BBK in the front and I'd like to get your point of view about the fitment ?
thanks
Old Dec 30, 2011 | 04:34 AM
Jim@tirerack's Avatar
Former Sponsor
They will not fit without modification.
Old Dec 30, 2011 | 08:53 AM
panta's Avatar
What kind of modifications ???
Old Dec 30, 2011 | 12:22 PM
Mar48's Avatar
If you are going with the right tire sizes you will need a pull/flare in front and maybe in the rear also. Camber will also be necessary.
Old Dec 30, 2011 | 02:09 PM
Froth.'s Avatar
They will fit, you will need to do some work to the fenders. Roll/Flare and relocated tab in the rear. Also depends on ride height.
This is 18x8.5 +29 (225/40) and 18x9.5 +41 (255/35)
How low you are is the depending factor on how much camber you'll need to run. Also tire size. I personally would recommend a 245 or 235 rear with a 215 Front. This will take decidedly less fender work and a small amount less camber to clear. The car above was daily driven never rubbed unless it was at full lock on the front.
Old Dec 30, 2011 | 10:56 PM
panta's Avatar
thanks all for your answers !
I've got some works already done on the fenders and I'm a little low too
Do you think that they will clear with the brakes ?
Old Dec 31, 2011 | 12:39 PM
Mar48's Avatar
I would say that almost for sure those will fit over a BBK
Old Dec 31, 2011 | 10:55 PM
panta's Avatar
thanks a lot for your help !!!
muche appreciated !
basulie
Jul 29, 2015 04:19 PM
aznvietboy725
Mar 24, 2012 01:47 AM
hioutput
Jul 9, 2009 11:51 AM
jib2222
Mar 21, 2008 01:52 PM
rosica
Aug 31, 2007 07:19 AM
