Steelie fitment - s2k
Hey guys,
I recently purchased a set of blizzaks on oem honda 16" steelies..The rears fit fine but the fronts didn't due to the bigger bore size on the s2k front spindles.
I was told 16 x 6.5 +50 aftermarket steelies will not fit and hit the caliper.
Does anyone know what specific size steelie I would need?
thanks.
thanks.
i had a front pair of steelies that fit fine. I think the bore on the wheels were around 73mm as they were universal?
You could also run a spacer. I ran into the same problem after i bought another set of steelies. 8mm was a bit too much, but i think you could get away with 5mm. space it out from the hub, so that it doesnt need to fit around the bore...
