STI rims
Old Jul 15, 2009 | 10:37 AM
gpmiami305's Avatar
Default STI rims
i have a set of bbs rims off a 2006 sti and i wanna put them on my S, but i heard that they wont fit, but ive searched on it and ive seen a s2000 with them on, does anybody kno if i can make them fit??? and how?? thanx
Old Jul 15, 2009 | 10:47 AM
RavynX's Avatar
Most Subaru STi's are going to have bolt patterns of 5x100mm.
Offsets are around +55
S2000 bolt pattern: 5 x 114.3mm
Offsets are +55 front +65
The bolt pattern won't fit but the offsets would. The ones you've probably seen are just aftermarket BBS wheels with the correct bolt pattern that look like the STi rims.
Old Jul 15, 2009 | 10:56 AM
jtree's Avatar
i thought center bore was smaller on the sti wheels. you'll have to enlarge the bore to 70.1 mm to fit the s2k's front hub.
^ the later sti's went to 114 bolt spacing. i think 2006 has 114.
Old Jul 15, 2009 | 11:00 AM
JP Money's Avatar
^2005 and newer have the 5x114.3 bolt pattern like the s2k. So the only thing you really need to do is enlarge the hub bore, so take them to a machine shop and let them have at it!
Old Jul 15, 2009 | 11:03 AM
gpmiami305's Avatar
thanx 4 the feedback guys but i dont think these are aftermarket they look like the stock sti rims, heres the link i saw
https://www.s2ki.com/forums/index.ph...ic=383899&st=0
Old Jul 15, 2009 | 11:19 AM
1nate7's Avatar
They are stock STi wheels. It's already been covered, 05+ will work but you need to bore the center to fit over the front hub.
Old Jul 15, 2009 | 11:54 AM
gpmiami305's Avatar
ok cool thanx alot guys ill post sum pix up as soon as i put them on, hopefully there gunna look nice
Old Jul 15, 2009 | 11:58 AM
s2k dre's Avatar
They look pretty good on an S.
Old Jul 15, 2009 | 01:42 PM
greenjack's Avatar
Wonder how it would look lower...maybe with some spacers?
Old Jul 15, 2009 | 01:50 PM
IlleztImportz's Avatar
so only two wheels for the front would need to be bored? does it need any special tires or would the oem subaru's work?
