stock S02 tire pressure?
Old Sep 10, 2003 | 02:58 AM
03s2kman's Avatar
Default stock S02 tire pressure?
what tire pressure would be best for a stock s2k?
Old Sep 10, 2003 | 05:21 AM
Jim@tirerack's Avatar
Former Sponsor
What ever Honda has printed on the door.
Jim
Old Sep 11, 2003 | 04:12 AM
CoralDoc's Avatar
Jim - I respectfully disagree with this as a general statement. However, I agree in the specific case of the S2000 .
Manufacturer recommendations are often compromises to achieve long life, a comfortable ride and to allow correct load handling. The door jamb sticker in my car lists 32 psi, which I have found to be a good starting value for even tire wear and good street handling. I usually run a more pressure (+3 to 4 psi) up front and sometimes also increase the rears a little (+2 psi) when I'm going to be pushing the car on the highway.
All other cars that I have owned have manufacturer suggested tire pressures that were too low for my preference of improved handling even though ride quality diminishes.
Old Sep 11, 2003 | 05:25 AM
Former Sponsor
He did not ask for specific applications. For general use the Honda spec is best. If it is for aggressive or track then you have to find what works best for you and your car in what track condition. For instance the Pilot Sport Cup likes lower air pressures than the other R compound tires.
Jim
Old Dec 16, 2004 | 11:32 AM
Costas's Avatar
edit: nvm.
Old Dec 19, 2004 | 07:16 PM
Matt_in_VA's Avatar
Community Influencer
Hmmm? The old tire pressure debate?
IMHO, I agree that 32 PSI is a good starting point. For agressive drives I find that 34 PSI feels good. However, if one is auto Xing higher pressures (I.E. 36 or 38 may work for you. I do not Auto X but base this on experience) On the track, it becomes a whole other matter however. Based on track conditions, ambient temperature, track temperature, etc.
At FCT04 I started off at 34 PSI and then bleed the pressure down as the tires started to feel greasy after the track warmed up and the tires heated up.
oldskooleskimo
May 27, 2010 10:21 PM
winson123
Jun 5, 2006 04:59 PM
Driv300mph
Jul 29, 2004 06:29 AM
genghiskwong
Jun 11, 2003 01:23 PM
cdelena
Feb 5, 2002 04:57 PM
