thinking of getting wheels, need some advice.
Old Mar 3, 2003 | 10:09 PM
S2Kay's Avatar
Default thinking of getting wheels, need some advice.
What do you guys think if I get a set of 18 X 7.5 for the rear and 17 X 7 in the front? Will it look funny or will it work? If not, is it possible if I get four 17 X 7 rims and just get wider tires for the rear? What tire sizes for front and rear if I do go with 17 X 7?
Old Mar 4, 2003 | 05:53 AM
Unicron's Avatar
S2Kay,
Unless you are going for show...I wouldn't run anything less than 17x8.5 (+55mm offset) in rear.
Reason is that you want to at least be able to use 245/40/17's. You can run 245/40/17's on 17x8 (+50mm offset), but I would go as wide as possible as far as wheel width.
CE28N's, Volk Racing
17x7.5 +50mm
17x9 +63mm
tirerack.com has some ASA's that are 17x9 with +55mm I beleive. They also have some Prodrive 17x8.5 +54mm. Please double check the offsets if you plan to order from them.
Old Mar 4, 2003 | 01:47 PM
Jim@tirerack's Avatar
Former Sponsor
S2KAY, You can do either one you are looking for but I would recommend a wider wheel and tire on the back. I would do a 17X7 and 17X8 or 9 on the rear. With the 18" rear I would go with something in at least 18X8.5 fro the rear.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Old Mar 4, 2003 | 06:03 PM
S2Kay's Avatar
Do you have any rims for around $800 or less without tires.
shadowz64
Aug 30, 2010 09:02 AM
GpWaP1 s2k
Apr 7, 2010 02:04 PM
Dr Jekyll
Aug 4, 2007 11:01 AM
Fuelrush
Feb 13, 2007 11:50 PM
mwilly00
Feb 10, 2007 09:09 AM
