Thinking of joining all you squares
After finally tracking my car this summer I'm really considering going with a square setup instead of my staggered set up I have now. I want to keep an aggressive look though. Does anyone know the stock hub to fender distance? It would really help in calculating how wide and how low of an offset I can get away with. I've ordered downforce fenders and I'll get some over fenders for the rear as well if I need to.
Not sure of the distance, but people have tried things enough to know what works. In terms of flush with the rear fender, a 17x9 +45 looks pretty aggressive. People have gone with lower offsets but once you do that, it gets a good deal harder to avoid rubbing. About the lowest offset for the rear fender with rolling and no overfenders is either a 17x9 +40 and 17x9.5 +38, and I am referring to with a propper size 255/40 tire. For the fronts on stock fenders 17x9 +60 actually looks pretty decent...people have fit 17x9 +45 with rolled fenders but it starts to poke a little bit. A lot depends on your budget too of course...if you have no budget, the Volk 17x9.5 +47 would fill up the fenders pretty well and you wouldn't need overfenders in the rear. If you'd rather spend more money on cutting your fenders and putting on overfenders then a 17x9.5 +38 or 17x10 +38 Enkei RPF1 would probably be good. Go to the Gallery section and look for the OFFICIAL Nonstaggered and Meaty Tires thread for ideas.
I was actually looking at 17x10 +35 all around. I'll have 30mm more to play with when I get the new fenders. I was looking at one S2000 in particular who has 17x10 +38 with a 5mm spacer and all that's done to it is flared fenders and over fenders. They also had 255's all around. I was just wondering if it was possible. There's an offset calculator online that will calculate the distance of your tire to your fender so that's why I needed the measurement. I'll just check when I get home today.
Just so you know, once you go lower, you will rub. I am quite picky on rubbing tyres so I flared and pulled the fenders which solved the issue.
Thanks for the help. Looks like he still has a bit of room in those DF fenders. I crunched some numbers and did some measurements and I think it's going to barely fit as long as I stay within a reasonable height.
pity i dont have coin for some nice fenders else I would have gone for more poke than the RPF1's
http://www.maxrev.net/widetires.htm
Be careful who you listen to!
