S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Tire install avoiding rim damage (https://www.s2ki.com/forums/wheels-tires-56/tire-install-avoiding-rim-damage-1143310/)
Mijae007 Jan 12, 2016 01:14 PM
Hi guys i just got some new volks and dont want them getting damaged in the tire mounting process. just wondering if anybody has any suggestions for mounting tires avoiding any damage on the lip of the rim.
I was thinking of taping the upper and outer edges of the lip before installing the tires to add a protective barrier...
EELPIE Jan 12, 2016 01:34 PM
Look around in your area for shops who have high end customers. They probably have a "touchless" machine. These tire machines can change a tire without actually touching the wheel.
Might be more expensive, but cheaper than a scratched or bent wheel.
jr94513 Jan 12, 2016 03:23 PM
Usually installing brand new tires on new wheels is no problem, unless you have no idea what you are doing. Usually the hard part is dismounting a old tire off a wheel without damaging it
FromaDB2toanAP1 Jan 12, 2016 03:38 PM
Look for places that use the plastic covers on the clamps. I believe for the Volks, tires are mounted from the back of wheel, taping the outer edge might help. Just need to find someone skilled, I'm usually straight up with the tire tech and ask if they are confident enough to mount/dismount without scratching my wheels. If not I'll find a new place.
Mijae007 Jan 12, 2016 04:03 PM
Just checked with costco said they use a machine that doesn't even touch the wheel and use nitrogen to fill up the tires. Told me to request for a more experienced tech too. And at $15/wheel, can't beat that!
meccjoo Jan 15, 2016 10:44 PM
Hit the nail on the head. I would also like to add that it is especially more so if you have low profile tires with stiff sidewalls.
Mijae007 Jan 16, 2016 05:30 PM
You're right. They installed the tire with the wheels facing down. Wheels came out scratch free :) +1 for la habra costco.
© 2026 MH Sub I, LLC dba Internet Brands
