Tire Size Question
I just got my first set of wheels, and I need some help on tire size. Here are the specs.
17x10+60 Rear
17x8+48 Front
Lowered on espelirs. What Size tires should I run? I was thinking 275's in the rear. And could you note the height as well?
Thanks
Paul
17x10+60 Rear
17x8+48 Front
Thanks
Paul
That is a lot of wheel and with that offset I would think you are going to need to modify the fender lips and maybe run more negative camber.
The front is going to need to be 225/45R17 and the rear would have to be 265/40R17 or 275/40R17. The 275/40R17 is actually too tall with the 225/45R17 in the front but I don't see anything else working.
