tire tread question, when to replace?
please no flames, i tried the search first but never really found an answer. is there a quantitative measurement for when the tire should be replaced? i'm going on 9k miles and drive it pretty easy (cept when i go to the track which is about three times per year). i have about 1/8" of tread on the backs and about 3/16" on the fronts. is it time? can i milk some more easy driving and just avoid the track (if that's possible) for awhile?
ty, jon |
Wait until you see no treads toward inside. You will know because car's handling becomes squirmy.
Use your tire's wear bars as a guide. That's what they are there for. When the wear bars first start to show, that's when you should start to hunt for new tires.
The wear bar is at 2/32". They are legally worn out at that point. If you go down that far wou will have bad wet traction at that point so slow down.
If I can help let me know. Thank you Jim 800-428-8355-364 |
I had to replace my OEM rear tires just before I got to the wear bars, maybe a 1/16" above the wear bars. I had 12,000 miles and they started to hydroplane in the rain. In my book, once the tires start to hydroplane, it's past time to replace them. It pays to keep a close eye on them when they are close to being worn out.
| All times are GMT -8. The time now is 04:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
