Tires...
Have any of you tried the Yokohama AVS ES100 tires or Pirelli P7000 Supersport tires?
245/45/16 rear and 205/55/16 front
If so how are they for a daily driver? I need tires now that will last longer than the SO2s or SO3s.
Thanks
Thanks
JDMs2000,
I currently have them in the rear...255/35/18's.
Performance isn't that great...but they are good for commute, and they are really cheap. I think these tires will last me a while...about the same as the T1-S. Last set of T1-S tires lasted me about 12,000 miles.
Other thoughts:
Sidewall is soft.
Will handle water pretty good. Not as well as the T1-S.
Dry weather grip isn't that great at all. About the same as T1-S.
UTG's
S02 - 140
S03 - 220
ES100 - 280
Other thoughts:
Sidewall is soft.
UTG's
S02 - 140
S03 - 220
ES100 - 280
I'm looking at switching to the Yokohama AVS dB tires for the back end... they cost $95 each from Tire Rack and are Ultra High Performance All Season tires... I need something that works in the wet (and sometimes slush!) here in PA. Any other recommendations?
I have about 9800 miles on the OEM Bridgestone tires... they're basically as smooth as Indycar tires.... is that typical tread life?
thanks all,
Donny D
thanks all,
Donny D
The P7000SS do tend to get noisy with uneven wear. They also are one of the poorer all season tires in the snow.
I like the Dunlop SP500 if you do need the all season. They are priced at 100.00 front and 112.00 rear.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
Well I will be ordering SO2s next week. I just had the Yokohamas installed today and I had to raise my car up an inch and cant deal with the gap, so off with these tires. I made a mistake. The ride was a lot better than the SO2s but they rubbed like there was no tomorrow with the Spoon wheels at a 2.5 inch drop. I even rolled the rear fenders and the 245s still rubbed like crazy therefore I am back to the SO2s.
s_tu_k
May 22, 2005 12:36 AM
