Verifying correct measurement for the front center bore
Old Mar 15, 2012 | 12:17 AM
OVER 9000!'s Avatar
Default Verifying correct measurement for the front center bore
I've recently decided to run ap1 rears on the front of my s2k and I found a machine shop to bore them out for me. All I need to do is give them the size I need the wheels bored to, so I thought I'd double check my findings on teh internetz with you guys to make sure. So is the oem front center bore 70.7mm? Thanks!
Old Mar 15, 2012 | 04:59 AM
WhiteAP1ftw's Avatar
99% sure of that.
Old Mar 15, 2012 | 11:59 AM
OVER 9000!'s Avatar
Okay thanks! Got another member that said that too so I'll tell the shop to bore the wheels to 70.1mm
Old Mar 15, 2012 | 12:21 PM
No prob! Tell them to go to 70.2 if you have rusty hubs
Old Mar 15, 2012 | 01:26 PM
OVER 9000!'s Avatar
Ehh if I remember correctly one of the hubs is pretty rusty and the other is not so bad. Should I just do 70.2 for both wheels? Will that extra mm be enough to cause any noise?
Old Mar 15, 2012 | 01:36 PM
Originally Posted by WhiteAP1ftw' timestamp='1331842905' post='21512301
[quote name='OVER 9000!' timestamp='1331841576' post='21512214']
[/quote]
I was mostly goofing around. The extra .1MM won't cause any problems if you properly tighten the lug nuts.
You should probably use a wire brush to be rid of any surface rust you can get off.
Old Mar 17, 2012 | 09:40 AM
s2cho's Avatar
this was a big pain for me!!!
https://www.s2ki.com/s2000/topic/930...#entry21430223
Old Mar 18, 2012 | 02:06 PM
AndrewLin's Avatar
i had my bbs' bored out to 70.3 and have had zero issues.
01S2kChad
May 17, 2013 01:34 PM
rob!
May 28, 2008 05:36 PM
