WedsSport SA90 over Stoptech
Does anyone know size spacer (if any) will be required to fit over a Stoptech BBK with the 17x7.5 +50 SA90 wheel?
Was it ever confirmed that the SSR GT7's in 17x7.5+48 fit over stoptech and can anyone even still get those?
Well I dont wait and myself had the old Wed Sports wheels with a 17x7.5 +43 front. We needed a 5 (or higher) mm spacer to clear our Endless with the +43 so your at a +50? You will need a minimum of a 12 mm spacer AND extended studs with open end lugnuts. I also hope you have wider front fenders since you will probably not want to rub.
Good luck.
Good luck.
The Prophet.
Aug 21, 2018 02:02 PM
