What do I ask for?????
Old May 7, 2003 | 10:26 PM
Ravskau's Avatar
Default What do I ask for?????
I am about to buy a pair of rear tires......
If I go into the local Bridgestone store and just ask for a pair of Potenza S02's
and specify the size or tell them I want them for an S2000 will I get the "proper" tire or do I have to go to my dealership to get the "special" S02 that it is my understanding that is made only for the S2000.
To complicate things even more , Should I just fit a pair of S03's
T.I.A.
Jim
Old May 8, 2003 | 06:43 AM
Gloffer's Avatar
1. Find a local tire store that will accept a shipment from TireRack.
2. Call Jim at TireRack 800-428-8355-364 and order a set of S2000 specific S02's. Rears should cost around $160 + shipping of about $20.
3. Two days later or less go to the tire store and get your tires mounted and balanced paying attention to the directional arrows.
4. Pay the tire store about $15 per tire for valve stems, mounting, balancing, and environmental fees.
5. Be prepared to do this all again in about 10,000 miles for all 4 tires.
6. I'd recommend against mixing s03's with S02's. If your going to use S03's then change all 4 tires. TireRack is probably your best bet here too.
7. If you go to a local Bridgestone store, they're going to have to order the tires anyway, and they'll probably cost over $200/tire + mounting, balancing, and sales tax.
Do some searches and you would have been able to confirm this without further ado.
Old May 8, 2003 | 07:57 AM
Jim@tirerack's Avatar
Former Sponsor
Thanks Gloffer for the plug. I do appreciate it. We have the OE tire in stock at 152.00 per tire and can have them to you within about 2 working days. I would not recommend the mixing of tires on the car either. You can end up with unpredictable handling.
Let me know if I can help.
Thank you
Jim
Old May 8, 2003 | 09:05 PM
Ravskau's Avatar
[QUOTE]Originally posted by Jim@tirerack
[B]Thanks Gloffer for the plug.
XtymourX
Apr 17, 2006 07:20 AM
cashout
Nov 5, 2003 03:29 AM
mdb
Feb 27, 2002 02:29 AM
Notion
Feb 6, 2002 12:15 PM
scottrnelson
Aug 24, 2001 05:39 PM
